Added 500lb fat sacs on top of the factory ballast tonight. Did this by splicing into the factory overflow/vent line, then route it into the fat sac, then vent the fat sac back to factory vent line. I really like this because it is still all controlled by the factory gauges. Here are a few pics.
Triple checked to make sure that I cut the vent line and not the fill line.
Splice the new tubing
This was a pain because the vent line was zip tied to the fuel line and vent. After pulling the vent line I was able to reroute it back towards the transom. The tubing that goes up and meets the U-shaped joint is the fill line. It is brought to a high point so the water won't flow back out via gravity.
Finished product. An extra 500lbs in the corner. Will be good for surfing.
