Has anyone ever thought of putting push button start on your tige, i think it would be kinda cool and different, even though i found malibu is doing it now
Push Button Start
Yes I did it last year. Nautique has had it for yearsssss. But the unit I had was simply a push button.... not coded. So I removed it. To do it, you will have to wire in a seperate switch for your accessories (I.E. Radio). It's pretty simple to do.Being a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
do they make any that are coded? I think it would be kinda cool. The new Toyota camrys have it now where there is no spot to put they key, you just leave it in your pocket or somewhere in the car and it knows. Also when you go to unlock the car as long as the keypad is close to the car you just push a button on the handle and it unlocks. So much for wiring an extra key under the fenderI don't do than anyway
Tige Throws Mad Wake.
Check this out...
http://www.foreandaftmarine.com/710-87-859660Q1.htm__________________________________________________ ________________________
2000 Tige 2100V Sold
Originally posted by ktmrider1 View PostCheck this out...
http://www.foreandaftmarine.com/710-87-859660Q1.htmTige Throws Mad Wake.
Cool idea though15 Escalade ESV-Black
08 RZ2-Blue
http://www.foreandaftmarine.com/710-87-859660Q1.htmwww.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Originally posted by samw View PostThat is pretty cool but what happens when it goes bad and your in the middle of the lake??? With a key you could hot wire it you need to.
Cool idea thoughwww.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
