Removing Prop?
    Removing Prop?
    Hey everybody,
    I'm wondering about a efficent way to get my prop off without a puller? Obviously I do not want to damage the driveshaft, is there any other way to get that thing off or should I just buy the puller? Thanks!
    I use a harmonic puller. It looks like a large coupling nut. You tighten it on by hand and back it off about one turn and smack it with a hammer and the prop pops loose. It helps if you have a flat bar of steel to use like a punch to lay flat against the rudder you hammer on the flat stock so you dont hit the rudder or prop.
    Harmonic puller works well and cost alot less than a prop puller. Ken
    Kenny
      i used the same thing and tap it soft with a rubber mallot and it comes right off, least mind did.
      Dom
      Originally posted by G-MONEY
        Where can you get a harmonic puller? NAPA? Walmart? Thanks for the advice!
          http://www.marinepropshop.com/acmeprops.html
          This is where I bought mine. Ken
          Kenny
