New to tige
    one more
      Originally posted by Lucky 275 View Post
      one more
      Its hard for pictures to give a wake justice, but that def. looks like it will do. Can you tell me how you have your boat weighted in those pics?
        jclay5
        4-5 adults in the boat. 400-500 on each sided, and 500 lbs of lead headz up front, if I remember correctly. This was long before FlyHigh was making the bow sac.
          Originally posted by jclay5 View Post
          I've been wakeboarding for several years and I've never ridden in or behind a tige. I am thinking of purchasing a 2000 21v with 350 merc and taps. I'm curious as to all owns this particular boat and how they like it. I would also like to know what people think of the 21v's wake and if they weight the boat in addition to the taps and if the boat has a center ski locker for a center fat sac. any information would be great. I might just be the next tige owner.
          Does a 2000 year model 2100v have a wooden floor or fiberglass?
            Wood layered in fiberglass.
              Wood lasted until 2004
              Common Sense is not so Common
                Mine's lasted longer than that and I suspect that Teamallen's has as well.
                  No im talking about tige used wood in boats until 2004
                    So whats an easy way to check on a 2000 model 2100v if the wood is good?
                      Open up the floor to the stringer and check it for discoloration would be one way.
                        Does that mean the 04 model boats dont have the wood?
                          Newbie , on an older tige
                          Ok, so i took the dive and bought an older (96) used Tige skiboat.
                          Ive taken it out once, just for a day skiing. Seemed fine, perhaps a tad underpowered , a little rattly. But it seems to run great. Now keep in mind, i have never actually owned a boat......
                          I am informed that i can switch out the prop, currently a 3 blade 1 1/8 lh 13 x 13 stainless, with a few nicks and chips in it, for a 4 blade and this would most likely smooth out some of the roughness and rattles, Of course, being a newbie, i have no idea who to call, and west marine had nothing available.
                          I am in the norhtern california (marin county) area. Suggestions on who i could call? Even for repairs and general stuff to improve it? But i would mostly like to switch out the prop......350 chevy i am told, is the engine......
                            I just bought a refurbished Acme 537 from Prop MD.com for a great price and I love the difference it has made. They were great to deal with also.
                            http://www.propmd.com/
                            __________________________________________________ ________________________
                            2000 Tige 2100V Sold
                              Excellent
                              Thank you,
                              I will check it out asap!!
                                also when you get a new one, you can get a lower pitch prob to give you a better holeshot. You will loose a little bit of top speed, but tiges are not meant for top speed anyway. I am supprised that your marina could not help you out. They should be able to get you a new one.
                                Tige Throws Mad Wake.
