Mysteriously got a small, Maybe 1-2 inch rip on the top of the seat backing in my 22ve. Any suggestions on how to fix it? Do I need to replace the whole cushion?
seat rip
If i have one complaint about our TIGE' it is the interior. Ours is seperating at the sewing seams on a number of cushions. I took it to an upholstery shop and they did fix it but he said it is only a band-Aid the materiel that Tige' used is just not of good quality. Not looking forward to having to replace it but it will need to be done sooner or later.
I had this happen on my old boat. If you take it to an upholstery shop the can match the fabric and replace just the panel that was ripped. You may need to call Tige to get the upholstery color. It is an easier fix than you would think. The only issue would be if the upholstery is bleached."Injuries heal, but puss you take to the grave."
Originally posted by Bandsecurity View PostThe only issue would be if the upholstery is bleached.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
