I know I should have put this in the ballast topic section. I was wanting some help fast.. My gate valve wont open. Is their anyway I can check to see if its Bad?
Rival Ballast gate valve??
There's a screw head on the side that is for manual operation. Probably frozen up like most of the others seem to do.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Just don't put that in the system and you don't have that problem.. OK I am having a bad day. I know I need to be a little more polite on my post today.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by dogbert View PostI'd PM lee, he knows how to work around it. Also, talltigeguy had an issue with his and figured out how to make it work.Originally posted by SPBFAN View PostJust don't put that in the system and you don't have that problem.. OK I am having a bad day. I know I need to be a little more polite on my post today.
There is a little silver screw on the valve. I broke the screw trying to get mine to shut.
The best solution is to get rid of it, or plan on replacing it every time it breaks. Mine broke in the open position, so I kept getting ballast even when I was just cruising or tubing.
My next system will be the same, but I will use a mushroom instead of a scoop and then I will just have a manual turn off just in case of a failure. That is what I did when mine broke and it works terrific. Getting the scoop out was a beeatc....I mean bear. I caused some gel coat damage in the process, which you will most likely do also.Be excellent to one another.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
We all have them.
Sounds like you need another day on the lakePut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Originally posted by talltigeguy View PostSB, not like you to be in a bad mood. Hope things are OK.
My next system will be the same, but I will use a mushroom instead of a scoop and then I will just have a manual turn off just in case of a failure. That is what I did when mine broke and it works terrific. Getting the scoop out was a beeatc....I mean bear. I caused some gel coat damage in the process, which you will most likely do also.Originally posted by G-MONEY View PostGrumpy pants......
We all have them.
http://www.wakeworld.com/MB/Discus/m...tml?1215639463
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by da.bell View PostYou think SPBfan is having a hard day.. You should see this guy...
I can help it.........
HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA HA
We all have them.
Sounds like you need another day on the lakewww.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
This is good G You need to come up and go boarding soon.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Originally posted by SPBFAN View PostI got my new truck and can't tow with it yet. So I can't go to the lake. I need to get 900 more miles on it before I tow. Maybe tomorrow morning I will break that rule and tow with it anyways. I need some adjustment on the water.is that? Oh yeah, it's a Toyota...what a feeling!
Originally posted by SPBFAN View PostI got my new truck and can't tow with it yet. So I can't go to the lake. I need to get 900 more miles on it before I tow. Maybe tomorrow morning I will break that rule and tow with it anyways. I need some adjustment on the water.Drive it like you stole it!
Originally posted by SPBFAN View PostThis is good G You need to come up and go boarding soon.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
