That's true of bias ply tires, but should not be an issue with radial tires.
Carlisle trailer tire
Guest
Originally posted by 1Lab_trainer View PostIf you tow frequently and your tire do not sit for extended periods of time then they do not tend to flat spot like tire on boats where we have possibly April ti Octiber to use the boat and then it sits which help develop flat spots on the tires. Once you have a flat spot it will have a tendency to blow out at high speed trailering while the pavement is scorching.
BTW: I have an Extreme trailer with 4 Carlisle's
I know many people have already said that they dont like carlisle tires but my unlce has a 2005 lund 1950 tyee and he blew out all four carlisle tires on his way to canada, he took my advice and put on marathons and has not had a problem. All my trailers came with them and i always take them off and put on white letter ones.
I have had the opposite experience. I have had Carlisle tires on my Extreme trailer since original. 1997. I had my first flat tire last season. It was the fifth year on the second set. I am now on my third set.
I thought Carlisle is owned by Goodyear?
To get the tires off the ground, in the off season, just jack up the axles and place jack stands under them.Mike Allen, Tigé owner since 1997
I like my Goodyear's. I am now on the 4th year. I will be replacing them after this year for sure. I won't go into a fifth year with tire on a trailer. I think you are just asking for it if you do regardless the brand.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
I am currently in Havasu and ordered a Goodyear Marathon as one of mine is in the early to mid stages of separating. Discount Tire (same as America's Tire in Cal) here in Havasu does not stock Carlise.
I believe Carlise was purchsed by Goodyear around 5 years ago as I had 4 biased tires that came with my Extreme Trailer separate/fail and Goodyear warrantied them (Carlise's) replacing them with the Goodyear Marathons.
Trailmaster or Towmaster (I forget the name) is made by Greenball and is highly regarded by many of the tire guys I have spoken to. The speed rating on the Greenball Trailmaster/Towmaster is 65MPH as oppose to 55MPH of most trailer tires such as Goodyear for what that's worth.
Returning to your question, not sure who carries Calise in Havasu however I believe Discount Tire can get them upon request.
