Originally posted by Jeffe
View Post
Great Weekend saved by G-Money and TWS
Originally posted by dogbert View PostSometimes you suck up debris. That happened to me a couple of weeks ago. Trashed the housing, too.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
I’ve been having an Alarm the last couple outings that is the same sound the buzzer makes when starting the boat ignition. Yesterday I received an image on the digital dash when alarming that said Oil Low, next line had a 1 and then psi, next line said Threshold, last line had a 4. Going back to the previous when the boat alarmed the motor still ran with the same rpm’s. No reduction in power. We first restarted the boat which cleared the alarm. I then googled and found something on a thread that said possible overheating. We then noticed that the temp would typically say 150-155 when it was alarming and then when alarming we opened the engine compartment cover which quickly reduces the temp below 150 and cleared the alarm. Being dumb probably we tried a few more runs and found when the alarm went off we could open the engine compartment cover and get air to flow which would immediately clear the alarm. Has anyone heard of an alarm because the engine compartment is getting too hot. My blower hose was torn so I will be replacing that but it ran fine all summer without having to run the blower so that shouldn’t matter for this problem. The oil alarm happened last night when I put the boat back in the water just to do a little more troubleshooting. I found the V-Drive ATF low and after much investigation and talking with the previous owner I added 30w oil to it and it is now at the appropriate level. This did not fix the alarm. I also pulled the connector off of the temp sensor on top of the block and the gauge would stay reading 139 when disconnected but the alarm would still sound. Once again opening the engine compartment cleared the alarm. Towards the end of our short evening trouble shooting was when the low threshold oil alarm finally showed on the digital screen. I am adding oil today (previous owner used west marine 45w) and I’m looking into how to change my impeller also. Any help with how to change an impeller or find the right part would be amazingly helpful. Thank you.Last edited by Travis.carr1; 08-05-2023, 06:14 PM.
