of course it going to porpoise without a taps plate, the hull is designed to be used in conjunction with a plate to give variability in wake characteristics (as we all know).
the beauty of the hull is that is that it allows for large no weight wakes at lower speeds (with no porpoise), and when u want to go faster, u lift the arse out of the water using taps and sit flatter in the water.
its just a stupid comment to say that the taps plate is just a cover up of a bad hull design... the boat was designed like that and requires the plate for higher speed running. thesre is no doubt that tige could design a hull just like all the other brands out there which has one trim set and sits flat in the water, but thats just not their approach, that removes the ability to trim and change the wake...
ive ridden behind out boards, I/Os, waksetters, responses, various tiges and all will porposise given the wrong balance, especially the waksetter with wedge down.
you just have to drive a tige like it was designed to be driven and there isnt a problem... thats been my experience so far!!
i think the person who origninally made the comment, simply doesant know what there talking about!!
