When's The Worst Time to Have a Broken Bilge Pump?
Originally posted by talltigeguy View PostI had a ballast pump break the same way. It of course was the emptying pump on the bottom of the bag, so water was flowing out of the bag as fast as it was being pumped in. LUckily my bilge was working fine, so I could not figure out why the water was coming out of what I thought was the overflow, even after I shut off the pumping in. Of course it was coming out of the hole next to the overflow. It was one of those Oh SHIITE moments for sure.
I have to think there was someone or something that broke the bilge pump a long time ago and it was never detected until the bilge was full of water.
Tigé Expert
- Mar 2008
- 1396
- The Sunshine State
- 2000 Tige 21I Riders Edition, 1980 MC Stars and Stripes
To answer the title of this thread:
When there is water in the boat?
Did I win any prizes?"I feel sorry for people that don't drink, when they wake up in the morning, that's as good as they're gonna feel all day" - Frank Sinatra
When there is water coming into the boat!
LOL. My brother took my boat out on Tuesday. First time he has ever done it by himself. He did not know that I take the plug out and leave it out while I am not using it. Well the boat kept taking on water faster then the bilge would not take it out fast enough and ended up blowing the breaker, which he did not know. Anyways the water was so high that it was coming into the seating area. Worst thing was that the boat would not start to get it out of the water. Almost sank until they found the plug, jumped in and plugged it drained it on shore and then took it out for a rip. No harm. Only thing that quite working is the amp for some reason and it was not even close to the water.2016 Tige Z3, 2014 Tige Z3
Originally posted by loudelectronics View PostLOL. My brother took my boat out on Tuesday. First time he has ever done it by himself. He did not know that I take the plug out and leave it out while I am not using it. Well the boat kept taking on water faster then the bilge would not take it out fast enough and ended up blowing the breaker, which he did not know. Anyways the water was so high that it was coming into the seating area. Worst thing was that the boat would not start to get it out of the water. Almost sank until they found the plug, jumped in and plugged it drained it on shore and then took it out for a rip. No harm. Only thing that quite working is the amp for some reason and it was not even close to the water.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by loudelectronics View PostLOL. My brother took my boat out on Tuesday. First time he has ever done it by himself. He did not know that I take the plug out and leave it out while I am not using it. Well the boat kept taking on water faster then the bilge would not take it out fast enough and ended up blowing the breaker, which he did not know. Anyways the water was so high that it was coming into the seating area. Worst thing was that the boat would not start to get it out of the water. Almost sank until they found the plug, jumped in and plugged it drained it on shore and then took it out for a rip. No harm. Only thing that quite working is the amp for some reason and it was not even close to the water.If its not fun, Why do it?
Im lost... Where did the water come from??
We had something similar happen in my neighbors Nautique. I guess usually this results from clamps being too tight. The Fitting for the filling pump broke.... After we started boarding I noticed the boat was starting to lean more and more and then the wake was getting messy. Turns out pump broke, anything comming from the hose from the lake is comming in AND the bag was emptying. So what about 6-700lbs of water is sitting in the bottom of the boat? So we rushed to get to the lift hoping that I didnt take so much on that the lift cant pull the boat up, I got it just enough out of the water untill the motor on the lift starting struggling. so then I just pulled the plug there and watched it empty for about 20 minutes. Luckily we have like 4 spair pumps. Just replaced it and went back out (would have just taken my boat but didnt want to put gas in).
For Those About To Ride We Solute You
