Did you check the fuses on the amps? Have you taken the stereo electrical wiring back to the battery?
Im an idiot...help
amps arent even connected yet......
havent messed with the stereo other than wiring the 0 gauge which isnt even hooked up yet.....Everything happens for a reason
Originally posted by CP3 View Postthats not the problem any more, everything is ready to fire now that I got the wires straight. Now the new problem is when I hook up the wire like its supposed to be the warning light on the dash goes on and there is a toneCursed by a fortune cookie: "Your principles mean more to you than any money or success."
Update:
We got it figured out in about 30 mins and got it all fixed right.........and it wasn't CP3's fault
The power for main relays and breaker, on top of the engine, is tied into the alt output wire some where in the main engine harness. When CPS pulled the alt wire off the starter lug and relocated it to the new battery Iso, the breaker/relay block lost power.
Fix: cut 12v feed wire to breaker/relay block, and laid in new wire down to the starter lug so the relay/breaker block is receiving power as before.
while he was here we finished up the W/S-XXX box and set it up in his boat and wired it up. With absolutely no tuning at all, this thing was POUNDING
This one 12" has more bass, boom, bump, rumble, etc, then the CC230 in our showroom with 4 Rockford 12's
I'll post pics soon, as this will be going in my boat for our Tige Owners Day next weekend.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
thanks for the help chp.
and that bass was kicking. never heard that much come out of one subwoofer....
I think I do have a loose battery connection some where....when I go back thru my own wake or any wake the PP shuts off and so does the rpm gauge but they both cut right back on......Everything happens for a reason
