taps problem
    taps problem
    My 2001 20i thats for sale. the taps is not working. Last summer when i bought the boat the taps was not working. so I replaced the pump. It worked fine afterwords.. So my boat is at H2O Sports Unlimited for sale. Some one wants to buy it. Guess what the taps does not work again.. Any Ideas?? The pump is freaking new...
    Is the pump not working, or the guage isn't working? That's the first place we need to look.
    If the pump is working but not the guage, it's probably one of the wires on the back of the guage has came loose.
    If the pump is not working, trace back the green wire from the throttle (make sure it's connected) back to the pump and make sure it's ok. If it's good to go, make sure the taps power and grounds are connected. If all the wiring looks good, then it's probably the pump
    Being a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
      Check the fluid level.
      Maybe a leak in the hydraulic line causing the reservoir to drain over time.
