Originally posted by chpthril
View Post
broken seat bottom
Originally posted by Matt Garcia View PostI just had that happen to mine on my front starboard seat base. Not sure how it happened. I am thinking it maybe from having a ballast bag up there while surfing.
Guest
I can't believe the seats break that easy. There goes a few votes for fit and finishEven with all the price drops this just should not happen.
I agree with you that the seats are not built to be standing on it. At the same time, good engineering should take in consideration that someone might stand on it and build a little safety tolerance there.
In my opinion, the material used on those seats are not strong enough. There are too many cases of the same issue.
Last edited by eks; 06-05-2008, 01:35 PM.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Well on my 01 21V I have a little seat behind the drivers side some one left a couple bottle in the cup holders and tried to open the seat fully (its on hinges) and ripped the screws out of the bottom of the seat and cracked. I went to parts store and got a two part epoxy from marine environment. I mixed it up filled in the old screw holes with epoxy and the crack and it is as good as new.
NO Worries at all. Just a thought.15 Escalade ESV-Black
08 RZ2-Blue
Originally posted by SPBFAN View PostI am with CHP on this one. You can buy your own staple brad gun at Lowe's or Home Depot for less than that I just had the back seat top white portion replaced they had to cut the raw material and sew it up and then recover the seat and it cost me $30.00. You can not even tell that the work was done. You guys are getting killed on price for that stuff.I don't want to go to work, take me wake surfing instead!
I had 2 seats break shortly after I purchased my '06 last year. The dealer took care of it with no qualms.
This is my 4th boat(different brands) and the first to have this issue with seats. We are extra careful with our Tige seats now. My buddy had his rear hatch replaced by Tige when one of his passengers stepped through it.
I think Tige needs to use heavier backing material on their seat backs, and hatch covers, personally....
Originally posted by kana12 View Postmine is an 06 22v and it happen when some one kneeled on it to grab somethin out of the water.. freakin junk.. i love my tige for sure but id be lieing if i said that their fit and finish was ranked anywhere near the top of the ladder..
Go look at the Malibu's and Master Crafts. They do not have more than TIGE' but the fit and finish is much nicer. I do like how they put a shower port in on the Master Craft. It has a Quick connector on the outside back corner of the the Transom and the power switch is on the dash for the driver to control. This way you are not fighting the storage compartment and all the item in it to get the shower out for use. It is those little things such as this that add up and make a difference.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Originally posted by SPBFAN View PostI do like how they put a shower port in on the Master Craft. It has a Quick connector on the outside back corner of the the Transom and the power switch is on the dash for the driver to control.
