it is about the size of a silver dollar.
how much to fix gel coat
about 38 bucks...$8 for the kit and $30 for shipping of toxic materials. Call your dealer and ask for the spectrum gel coat repair kit. Subsequent to an oblivious sea ray with stainless rubrail screws protruding, I used it on my red gelcoat and it works like a charm. Just be patient with the sanding and polishing afterwards, and mix the hardener per the included instructions.
FYI, spectrum is the company that makes the gelcoat that Tigé uses (currently and pre-2002). White will be easy for them to match, and they will use the same pigment that was used when your gelcoat was sprayed down.Freude am Fahren.
Originally posted by spharis View PostI would attempt that one myself. It isn't too bad.Freude am Fahren.
Originally posted by David Baker View PostGet a patch kit from www.spectrumcolor.com and do it yourself.Freude am Fahren.
Originally posted by Ruune View Posthe might be able to save on shipping if he can get his dealer to have it included in with another shipment.
a link:
http://www.spectrumcolor.com/catalog.htm
gel coat is SUPER easy. just be patient and follow the instructions included with the gel coat. for that small area you will be fine with the patch paste, don't order a quart unless you absolutely have to.
Spectrum will also provide some phone help if you get stuck, they're really good. You can also PM me and I can probably answer your gel-coat questions.
If you pay to get it done, I would expect that size (depending on how bad/long those scratches are before and after the hole) to be <$250 if htey have to order patch paste to color match or probably closer to $150 if it's a color they have in stock.
hope that helpsOther than that, Mrs. Lincoln, how was the play?
