Are you serious? I know they have enough power to pull a boat, but the boat loading/unloading area wouldnt be fun, plus you need another porthole on the fender to be in true classic buick fashion, unless one is hiding behind the railing.
I have no problems towing with a Jeep Grand Cherokee pulling a 20V on a Tandem Axle. Jeep is 4x4 4.7 liter semi loaded for a 2002 and it pulls the 20V easily on the Illinois flatlands and the hills of Missouri and Arkansas. We have towed a 23' Maristar numerous times and no issues as long as we pulled it out of OD.
The Jeep has penty of muscle but its GVWR is a tad low for when you haul 23 footers on up. One downs side in about 48k towing out of 82k total is it eats brake pads. I am ready for third set now.
most of it anyways.I have several of them(I don't know why)so I generally use the crappy one to pull not because its weak but because I don't like leaving it at the ramp.
