What does it cost you guys to have your props rebuilt? I tacoed one last year, nothing super bad but did vibrate kinda bad, they charged me 300 to rebuild it, is that as bad as i think it was?
WHAT!!! $300 to fix it. try 165.00 to max maybe $200.00.
Guy's I have access to a guy who straightens the shafts with in .001 if you bend them. So if you replace you shafts send me your old ones so I can get he straightened. He charges about $80.00.
And has invested in all the correct equipment to do it right. He has the computer and all. He will tell you if he can fix the prop or not. He guarantees the prop repair will not vibrate or he will replace it for free with a new prop.
Where are you located? I am not sure if the shaft is bent or not. I have to get a prop on and get it out into the water before it bends to see if the vibration remains. Am concerned that shipping might be prohibitive...
Sounds like it may be a good idea to float your boat off the trailer and push it until the water's deeper. Otherwise, find a new ramp.
Yeah, I havent had much success with that. Boat is big and heavy and does not want to float off. Other issue is that I am towing/launching it with a Ford Explorer and the tailpipe is quite low AND of course the ramp is long and shallow.
I cant get the trailer in far enough where all the bunks are submerged.
Sent PM
You can back it up so the tailpipe is under water--it won't hurt it. Just make sure you keep it running and the pressure of the exhaust will keep the water from doing any damage at all. I dip mine WAY in--almost to the rear tires sometimes- and never had any sort of trouble in anyway. The boat floats on and off easily then. Once in awhile I'll get a guy telling me (in a helpful manner) that I'm going in too deep, but I ignore them and do my thing.
Just have the truck in reverse and when the boat begins to float put the brakes on. The momentum will be more than enough to put you peacefully in the water without having to put the boat into reverse.
