This past weekend was loads of fun - except for the bent props! First bent prop was really bad - all of the blades were folded real good. Vibration was pretty bad, but we were able to get it on the trailer and out of the water.
Bought and put on another new prop for the next morning. My luck... took her off the trailer and as soon as I eased the throttle forward, the vibration was horrible! I actually dove into the water and felt one of the tips had folded. We were only 25' into the water with the new prop!!
Got her back out of the water and saw that 2 tips were bent pretty good. Was so upset, went to work and bent them myself! Put it back on and we were able to at least go out and pull a tube and a few skiiers. Could not go above 3000 RPM as the vibration was horrid. Underneath the 3K "barrier," it was livable. Sent both props to the shop to be repaired. I only hope that running around on that much vibration did not do more harm than not...
I dont think the shaft or strut are bent - they looked OK to me but time and the repaired props will tell. I sure am hoping that all is well when the props come back. Will know more next week.
