Just wondering if anything bad will happen to the boat if it has been sitting in the pouring rain without a cover for a day. It is a 2002 22iR there was nothing i could do about it. i know it is a boat and it goes in the water but just wondering.
rain in boat
Guest
Or get some bubble bath and use it as a tub for a day or two and then drain out the water It will be clean inside and out and no harsh detergents.
j/k
Originally posted by jake's02-22i View Postthat sucks maybe i will take the wet vac to it when it stops raining.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
A 100 watt light buld and a small fan will help make sure it drys out nice, if you put in under cover or in the garage. I'm sure the sun works wonders down where you at tho. Tricks of the trade, up here in Vancouver where it rains 9 months of the year and every five minutes in between. I also found those little dehumidifier containers that you can by at Costco seem to work ok too.
