Faria Commander and Fuel tank level gauge
    My fuel gauge has started sticking and Faria says it will take 5 to 6 weeks to get it fixed and returned. At this point I can still tap on it to get it to read the level and figure I should send it to Faria at the end of the season.
    My question is, the Faria Commander Tach gauge says (according to the Faria manual http://www.tigeowners.com/downloads/commander_tacho.pdf) that it should read the fuel tank level (as sent from the tank sender, not from a fuel flow sender which I don't have). Has anyone else seen this or figured out how to get it to read the fuel level?
    Here is what the manual says
    Ambient Air and Water
    Temperature
    Description
    The Faria Commander Tachometer/ Water-
    Air Temperature/ Fuel Level/ Engine
    Hourmeter combines the features of
    several instruments into one unit. The
    LCD displays the information for the other
    instruments:
    1) Water Temperature - Displays the
    current water temperature.
    2) Ambient Air Temperature - Displays
    shows current air temperature
    3) Fuel Level - Displays fuel level in fuel
    tank (based on level sender) in percent.
    4) Engine Hours - Displays the number of
    hours the engine has been run.
    My gauge scrolls through the Water temp, Air temp and Engine hours, but does not show the Fuel tank level.
