Ya thanks, you were right about the amp size, i will check it out when i go home for lunch, this is the first day my boat has not been at my office for over six months, now i need it here, funny how that works
New forum guy with questions
If the amp settings are correct, I would ohm out the tower speakers wires next, you may have one pinched under the tower leg.
Pull the leads from the amp, put DVOM leads across the + and - and check the resistance. Should be 4 ohms, maybe a shade over due to the length of wire. What you are really looking for is near zero resistance cause be the short.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostSounds like your tower speaker amp is going in to protect mode. May be due to a low impedance problem (short in tower speaker wires for example) or gains set too high.
Whats a impedance problem?
Is that when you cant get it up???www.integrity-wake.com
Supreme Tigé Master
- Apr 2007
- 12007
- Lake Carl Blackwell, Stilly, USA
- 54 Bellcraft, 56 Burchcraft, 61 LoneStar, 75 Catalina 27
Originally posted by ragboy View PostYes, and you have to be careful. Sometimes when you fix the low impedance problem, your amp will stick at full output for up to 12 hours and you have to take it in for service.
yuk yuk yuk...
Let us know what you find; sorry for hijacking the thread with the innuendo...It's not an optical illusion.
It just looks like one.....
