anyone ever have any trouble with their engine after the winter and it wont run past 1,000 rpm. I think it is a automatic safety switch for when the fuel is not the right mixture from maybe the anti freeze.
engine wont run past 1,000 rpm
Originally posted by byfor5 View Postanyone ever have any trouble with their engine after the winter and it wont run past 10,000 rpm. I think it is a automatic safety switch for when the fuel is not the right mixture from maybe the anti freeze.
10K RPM ??? I hope that's a typo! Your engine should max out at about 5,200 RPM, do you mean 1,000 RPM?
Ok lets start with what was done during winterization.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by byfor5 View Postthe red light goes off when i put the throttle down and i have the 340hp engine.
all the gauges seem fine nothings to hotMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by byfor5 View Postwell i have the two battery system but only ones hooked up right now because the other one is dead. do you think that is the problem?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I see you have a 2006 which was the first year for a drive by wire engine , with the dual batteries system if either battery gets .3volts or more differance from one another the engine can go to a limp mode and set a code 81, so charge or replace if needed the batteries and see what happens, there is also a modification that can be made to eliminate that problem. You should have your dealer scan the data to confirm there are no other problems. Hope this helps.
