Apparently he's got a secret desire to be a U Boat commander
When we first bought the boat we were warned not to turn into our own wake. I was not paying attention the second time out. Water came over the nose and my wife was yelling my name because she saw it coming and I did not. It was a big enough splash that we had an additional 500 pounds of ballast j/k I know it was a ton of water. Everything got wet. I have never done that since but who's do say that someone else might. I would just rather be per paired just in case than to be replacing everything.
My wife is a very good driver and my 15 year thinks we need to power turn all the time so he does not get to use the steering wheel just yet. He needs to change his mind set just a little before he gets the wheel.
That was one of the first things I taught my 13 year old. He appreciates the fact that I don't do power turns because it's kind of a bummer for the rider, too.
Here is the tower finished up. I need to get with G-Money on some wire for it that will cut down on the noise I get from the wire I used.
Does anyone have any pictures of a 2008 Ve with the Bimini top and tower speakers. I'm having a hard time understanding how they would hook up to the tower and still allow me to use my top. It directly attaches to the top wake tower cross bar.
I am thinking about turning the pro 60's out just a little bit rather than straight back. I don't know if it will make a diffrence or not but I need to try it.
Here is a crapy picture of the sub with some stuff in the way.
Post a picture so we can see it. I need a visual of what you have.
Will you be at the marina tomorrow? If so check out my Z1 in the showroom, the speakers will mount to the front crossbar instead of the rear.
We will be down pretty much all day if you want to take a surf run
