looks really good Duner, let us know how it works on the lake tomorrow.
TigeDuner's Ballast Install
Sorry for catching on to this thread a little late. Dunner I am very proud of your lay out. All those ours on the phone letting you talk yourself through it paid off. That is the nice thing about this system. You can do it your self and lay it out nice. G-Money kind of took the plunge for everyone and got the first system. Now that three of the systems have been set up and installed they are getting cleaner and fine tuned.
I am sure that you will have no problem with the pumps pulling water where they are. 20" of head pressure you are not even close to that. I can't wait to here how it works out.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Thanks again Andrew. We are all very anxious to get behind the new wake.
I was surprised how easy the wiring was under the dash. I installed 3 20 amp in line fuse holders which were long enough to make it from the switch wire to the terminal block. Pumps work fine. I just need to verify rotation. I am leaving the final wiring at the pumps to be completed at the lake. I will check in Sunday night with a report.
Originally posted by TigeDuner View PostThanks again Andrew. We are all very anxious to get behind the new wake.
I was surprised how easy the wiring was under the dash. I installed 3 20 amp in line fuse holders which were long enough to make it from the switch wire to the terminal block. Pumps work fine. I just need to verify rotation. I am leaving the final wiring at the pumps to be completed at the lake. I will check in Sunday night with a report.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert View PostI'd wire them up before you go to the lake and take a 5/16 wrench with you so you can switch the pump direction at the pump (Just rotate the impeller housing 180 degrees). It literally takes about 2 minutes. Be sure to use xpjim's final diagram. I found that all three of my switches had the wires in the wrong place.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
You are right, got home to late to post.
Everything worked great. Surf wake was huge and the wakeboard wake even better. My son landed his first tantrum and I jumped to new heights.
Observations:
Bags empty quicker than filling.
We were able to leave the main valve open all day with no drain down.
50 hose clamps and only one dripped.
One of the check valves cracked and was leaking so it will need to be replaced this weekend.
Check valves not needed in vents on the rear, but I might put one in on the front to get ALL water out of port side of the bag.
Quick disconnect fittings are a must. Made it very easy to remove front bag to dry out the front from broken check valve.
Boat accelerates slower with the additional weight and requires a few more RPM's to board at old speed.
Did not notice any real impact to Perfect Pass. It was able to maintain speeds for surfing and boarding.
Thanks again Andrew. Keep me up on any tweeks that are made to other systems. TDLast edited by TigeDuner; 05-19-2008, 07:59 PM.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
NICE!!!!!!!!!!!!!Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Cool. I am glad it worked out. Just like anything new you have to work out a few bugs. Now we need pictures of the surf wave and wake boarding..
Originally posted by Moki View PostNice TigeDuner!
Now all I need is schematic layout complete with instructions and instructional videowww.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
