Originally posted by xpjim1
View Post
TigeDuner's Ballast Install
Originally posted by G-MONEY View PostTall I have the PP on the same side of the scoop. We offset the two to make sure the were not in a direct line and on the water test we had no problems with PP holding.
I have to admit it was a concern when we did the install.
Originally posted by TigeDuner View PostI know I will need to do a "clean up" as well to some of the hose work. I could have made it with one 50' roll, but I would have needed to use more 90's, which means more places for leaks. The front sac was the toughest. I still need to tie in the port drain and it will be done. I would like to drill holes in the front compartments but not sure how far forward I can drill into the floor. This will clean up both of those compartments a bunch. For now, the hose runs from one side to the other thru the factory vent holes thru the floor.Let it be!!!
I am refering to the compartments in front of the driver and under the glove box - not where the sac is. I connect the two drains from the bow sac together and I went under the floor between the two compartments. I would like to drill holes at the front of each compartment to run the line rather than in the middle where the factory 3" vent holes are. I may just drill holes in front of the factory ones if I can't get all the way up to the front.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Have fun working with the #10 wires coming off the switches with #12 spliced in to the #14 off the pump....
Looks good tho...Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by xpjim1 View PostLooking good. Is the other cutout next to your access panel for yout table?
That's where my table mount is too.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Originally posted by TigeDuner View PostThe brass fittings at the pumps were the easiest to push on. The quick disconnect fittings and the pvc fittings required the use of a hair dryer. Once warm, they twisted right on.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by TigeDuner View PostAccess panel to valve and ballast switches
Originally posted by dogbert View PostYou need to eat some more Wheaties, son. I got mine on without the use of a hair dryer.Be excellent to one another.
