TigeDuner's Ballast Install
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Nice Job!!!!!!!!!!!!!
I am anxious to see how you route your plumbing and what pumps you chose to use to get the discharge out the side of the boat. For now, I am sticking with my 'aerators are better' mantra.Be excellent to one another.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Which side is your perfect pass paddle wheel on?
Is your through hull a backwards scoop or just a mushroom?
G - money has some slow but steady back drainage, did you put check valves in?Be excellent to one another.
Originally posted by eks View PostResistance is futile. Come to the dark side!
No, no, Darth is not my father....
At our next get together, I would like to see your setup. Get that thing water tested so we can see some pics of the new wake and you can let me know what you would have done different if anything
TigeDuner,
I am anxious to hear how well your setup worked once on the water!Last edited by Moki; 05-14-2008, 05:22 AM.
Originally posted by Moki View PostMust resist the temptation to do the same.... must resist the temptation to do the same.... This looks awesome so far.I feel that a project may be under way again!
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by TigeDuner View PostThe perfect pass is on the same side as the pick up. It is mounted backwards. The ball valve will stop any unwanted water and I did install 6 check valves, one on each fill and one on each drain. Hope to test this weekend.Be excellent to one another.
Originally posted by talltigeguy View PostAre you worried that the turbulence from the scoop will alter the accuracy of the perfect pass pickup? Let us know how it goes. This has been suggested as a possible problem with the scoop in front of the perfect pass paddle wheel, but I have yet to hear of any real life situations where that has been a problem. I hope it does not give you any trouble with maintaining consistent speed.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
TigeDuner,
Perhaps we could schedule a late afternoon at the lake next week for our next get together.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
