Have been real busy. The only thing I could find out was that with speedset if you are close to the set speed on the throttle itself the speedset does sometimes have a brain fart with the new '08's. Only if you hit it absolutely perfect in the sweet spot. Had no issues the last time after my 20 hour. Well the only real issue was that i picked up the boat from the dealer and went straight to the lake to show off my new stereo to my buddy and after the dealer also put in a 2nd deep cycle battery I had no tunes. Real piss off. But the dealer sent up his tech and got it fixed up on the lake.
You do know that the throttle needs to be put to wide open throttle when it, the Speed Set, engages. If you hold the throttle at the set speed, it will surge.
