Guys, should this housing be replaced with every impeller change? I have read up on this before, but this one is in great shape, except for a small nick in the gasket, no scoring at all on the inside. Thanks.
Replace??
No, but should be inspected closely when impeller is replaced. Look for scoring, grooves, and discoloration.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
jacques2727,
I replaced mine this year. I don't have any pics here at work but I will look tonight to see how my housing looked compared to yours. As I am looking at it now I think for the money I would change it. I will PM you some info on who to contact about it. You get everything you need. NOTE: you only need that half, you don't need the pulley end if it is not bent.
As far as changing the impeller: here is what I did. I used a shoe string and tied it around the bottom end of the impeller. NOTE: the impeller should be dry at this point.....(chpthril - told me to get some oring lube and I don't remember the name, I will take a pic of that tonight) I lubed up the inside the house w/ a good bit of the lube and the impeller slipped right in. I put the entire housing together one night while the race was on. I have picture of the impeller in the housing just so I know what direction the fins should be. The next day mounted the unit in the boat, took about 1 1/2 hours w/ the TV on.Dale
2000 21i Tige
Originally posted by wannabewakeboarder View PostI'll agree you dont need to replace the metal one unless of wear or scores...Whats the discoloration from chp? Always replace the gaskets or O rings or whatever they are. We use Vasoline to ease the impeller inMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
