I'm kind of in a bind with our Rz2 or trading for an Rz4. If I keep our Rz2 i would want to add Wet Sounds or Dbot5's but question is would Pro 80's ( 4 or them) fit with my bimini (stock). Another question is how would the they sound with Kickers in side the boat. Would I probably have to go with Pro 60's?
Wet Sounds and Dbot5's
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Get wetsounds over the Dbot'5.
As for pro 80's vs pro 60's there will be a good difference.
You could go with a set of 60's and 80's witch it's called the double-up I think.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
I run the 80s and 60s and love em. I've heard from someone that has the 80s and 485 and he thinks the set is too heavy and it shakes the tower. Not sure if anyone else feels that way, it could be an issue as well with 2 pairs of 80s. I could be off my rocker too though, just going off what I've heard.
Guest
Originally posted by buffman View Postdepends on tower as well.... I have seen the tige tower shake pretty good but my samson seems to be solid with the double up weight.
When on our favorite lakes in No Indianna we need to drop tower twice when going thru a channel that connects the smaller ski lake to the larger crusing / sandbar lake.
