Originally posted by eks
View Post
EK Ballast Install
Originally posted by da.bell View PostIMO, you are going to have the same problem of the bag being emptied if you use the same hole in the hull for your intake and outtake. I would take the outtake hole and put it up near the rubrails.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by da.bell View PostIMO, you are going to have the same problem of the bag being emptied if you use the same hole in the hull for your intake and outtake. I would take the outtake hole and put it up near the rubrails.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Yes, but the check values are there to direct flow. Per your schema (this is just my opinion) with or without the check values will do the exact same thing. Will allow the water to go into the bags via the pump and exit the bags without the pump. Someone posted a schema of the X-Star's ballast system and did you notice that the exit holes were on the side of the boat? This helps to promote the water to stay in the bags and not release a trickle of water..
Originally posted by da.bell View PostYes, but the check values are there to direct flow. Per your schema (this is just my opinion) with or without the check values will do the exact same thing. Will allow the water to go into the bags via the pump and exit the bags without the pump. Someone posted a schema of the X-Star's ballast system and did you notice that the exit holes were on the side of the boat? This helps to promote the water to stay in the bags and not release a trickle of water..
The pump would have to work to suck water out.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by eks View PostI thought that by putting the pumps higher than the bag I would prevent the trickle of water.
This is a crude drawing of how a guy on WW did his DIY Ballast Puppy install.Attached FilesMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
