EK Ballast Install
    You guys are making this look to easy so I may need to try it also. Where did you get the pumps from and why this choice for pump type? TD
      I will PM you information.
        That would be a hugh help. I want to start getting all the materials now for a rainy weekend this summer.
          One thing that I was disappointed about it is the thickness of the fiberglass and gel coat on the bottom of the boat. All together as about 1/4" thick on the bottom. I'll post some pictures later.
          Tige has gone really cheap lately on some stuff.
          The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
            Well, you still have the Lifetime Hull Warranty.
            But, 1/4 inches does seem a little small for that area.
              The side was what we expected about 1/2 inch or thicker. But the bottom is very thin.
                Thanks, I was happy with it.
                I got to figure out why the power is not coming though. The dealership did something to it and we are getting no juice.
                I also need to finish installing all the hoses and wiring the pumps.
                Where are you pulling your power & ground from? My first guess would be a missed wire eyelet at the "house" battery.
                  We tied into the open circuit breaker panel slots. We also put a fuse in the lines in addition to the circuit panel spots. On G's boat we uses the open spots on the + and - Buss bars under the dash.
                    There should be three wires on the positive side of the main battery.
                      Where you able to determine whether it was Pos or Neg that was missing? Odds are that everthing in the breaker box is hot or a lot of stuff would be inop.
                        He is missing power from the battery to the breaker box and yes a lot of other things were inop. We did not have a DVOM with us or even a test lite. My guess is that one of the 60amp fuses at the battery is blown. You are only as good as the tools you own and if you know how to use them. That is one of the tools I forgot to pack in my bag for the week. EKsilva knows what he needs to test to get it going. I am sure this weekend he will be working on it. Infact I am going to call him on the phone.
                          I'll still bet the farm on this one.
                          But, there are a couple of breakers back there by the batts, and one could be tripped.
                          Fixing is learning, learning is fixing(R)
                            I looked by the battery and I didn't see any breakers there, I did see 2 big fuses and they were both in perfect condition
                              Look on the transom wall, that's where they are located on my 06
                                I will, are they some breakers or fuses?
