Nice looking good
G-Money's ballast systems
Originally posted by KonaKing View PostMine comes in the back and I can still fill moving slowly
But I will wait to hear the feedback from Andrew and G when they are done.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by Matt Garcia View PostCool. Want to drive down to Texas and do mine?www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
These pumps are capable of 50 gallons of water in four minutes. 8.5 X 50 = 425 lbs of water. By the time you stop get your boards down put on your board on and get in the water the sacs will be full or close to it. And in reverse the same thing for emptying the sacs. 3 to four minutes max and with the sacs G has I would guess about 2 or 3 minutes and he will be ready to go. We put a vent port on each sac because I was told if we did not these pumps will rupture the sacs in no time.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Originally posted by SPBFAN View PostThese pumps are capable of 50 gallons of water in four minutes. 8.5 X 50 = 425 lbs of water. By the time you stop get your boards down put on your board on and get in the water the sacs will be full or close to it. And in reverse the same thing for emptying the sacs. 3 to four minutes max and with the sacs G has I would guess about 2 or 3 minutes and he will be ready to go. We put a vent port on each sac because I was told if we did not these pumps will rupture the sacs in no time.
One question on emptying the sacks, how do you know when to turn off the pump off when emptying the sacks since you never see that the pump stopped pumping water out?
Does it have a automatic off when it runs out of water?The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by eks View PostHow many lbs of ballast are you adding G?Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by Bibbs View PostJust curious, what is a system like that worth?
Not having to fill each sac individually with one pump over the side......
PricelessPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Does it have a automatic off when it runs out of water?Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Originally posted by G-MONEY View PostWe are working on that....
Just an Idea we were discussing yesterday. They will check to see how much it would cost, theirs guesstimating was around $50.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Backwards Scoop?
I assume that you already had the scoop and just wanted to be sure to use it? The mushroom through hull I have works fine, and I suspect it is significantly less costly than a full scoop.
BTW, I have an extra 1 7/8 inch scoop through hull if anyone wants it. It is the same one in my ballast install thread.
So the ballast puppies can suck water in from a port on the top of the sack right? So you do not need to have but a vent and a fill line on the sacks, correct?
Aren't there some reliability issues with the ballast puppies?Be excellent to one another.
