Taps 2 vs Taps
    Taps 2 vs Taps
    What is the difference in the taps 2 and the taps. I have Taps on my 01 and was just wondering what is the difference.
    Thanks
    Sam
    15 Escalade ESV-Black
    08 RZ2-Blue
    Thanks
    Sam
    I could be wrong, but I think the difference is on the ConvexV hull.
    The taps part I think is the same.
    The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
      Thanks
      Sam
      Excellent question. Had the TAPS on my '99, now have TAPS2 on my '06.
        So it's the combination of new hull with the same TAPS. If I compare the '99 with '06 TAPS, I do not see any recognizable differences just looking at it.
          My 01 has a vonvex hull with taps. So that is confussing????
          08 RZ2-Blue
            My original TAPS has 2 rams and is hydraulic, is the TAPS 2 electric and has only 1 ram?
              Laser
              That is correct I do have two rams and Hydraulic. So it that the only difference???
              08 RZ2-Blue
                yep, hydraulic and electric.
                  So if that is the only difference was there an issue with the hydraulic? Since they went to electric?
                  08 RZ2-Blue
                    I have an 03, electric, one ram, not taps 2.
                    I think it has something to do with the convexV
                    Common Sense is not so Common
                      TAPS2 I think was marketed right after Tige got their patents on the Convex V hull. If I am not mistaken TAPS preceded the patents so there may have been refinements in the hull design when they got their patents and marketed TAPS2 from an article I read. I think the modifications to the TAPS plate were irrelevant.
                        Taps2 is definitely hydraulic on th 07 22Ve...can't speak for others....
                          The hull.
                          Taps was basically a trim plate.
                          http://www.wakeboatworld.com
                          []) [] []V[] [])
                            I have an 05 with one hydraulic ram.
