Does anyone know what our fuel tanks are constructed of? Read an article today explaining how ethanol can begin to eat away at fiberglass fuel tanks...hoping we have aluminum, as more stations around here are blending ethanol into their regular grade gas.
Fuel Tank Construction
Good ol plastic.
Weil, did you get my PM about the Tige Owners Day?
Thanks for all the replies! Fortunately, Jason (smart@ss), it's an '07, so I haven't had to have it to the dealer, who is 3 hrs away. Have an independent guy who did my 20 hr service to keep it under warranty. I did just find that there are NO backing plates or nuts on my rear tower bolts!!! Not in the bilge either, so must not have been installed at the factory!
CHP, PM'ed you.
Another point about the ethanol...the article (Boat US mag) states that the ethanol helps break up varnish or gunk in your tank, so watch your fuel filters better too.
The rear tower bolts dont necessarly need backing plates, IMO. the stress from the back supports pushes down into the fiberglass, not like the front that pulls up. But it is nice to have that security thereEverything happens for a reason
Originally posted by Weil Thing View PostThanks for all the replies! Fortunately, Jason (smart@ss), it's an '07, so I haven't had to have it to the dealer, who is 3 hrs away. Have an independent guy who did my 20 hr service to keep it under warranty. I did just find that there are NO backing plates or nuts on my rear tower bolts!!! Not in the bilge either, so must not have been installed at the factory!
CHP, PM'ed you.
Another point about the ethanol...the article (Boat US mag) states that the ethanol helps break up varnish or gunk in your tank, so watch your fuel filters better too.Originally posted by CP3 View PostThe rear tower bolts dont necessarly need backing plates, IMO. the stress from the back supports pushes down into the fiberglass, not like the front that pulls up. But it is nice to have that security there
Now, to address the question. Tige glasses in 1/4 thick plate into the gunwale. The rear tower bolt hole is drilled and then threaded. The bolt threads through the glassed in plate, so from the backside, it looks like it's missing the nut.
Your tower is good to go, have your service guy torque them to about 22ftlb's.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by gman View PostWhat type of tank does a 2005 24v have?
GMAN, mine is aluminum same boat as your. Your is also aluminum. All the tanks on all the boats are aluminum from what I have been told by the TIGE factory.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
Originally posted by SPBFAN View PostGMAN, mine is aluminum same boat as your. Your is also aluminum. All the tanks on all the boats are aluminum from what I have been told by the TIGE factory.
07 22Ve HmmmmmAttached FilesMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
