Finally got pictures!!!
Here is the Wet Sounds 2008 RZ4 demo boat.
System Installed by Hydrotunes in Austin, TX. http://www.hydrotunes.com/ Huge Props to Justin and Trey at Hydrotunes!!
System Breakdown.
Tower: 1 pair of Wet Sounds PRO 485 with 1 pair of Wet Sounds PRO 60. Custom tower with straight bar. Billet Grilles with Blue LED plexi rings.
In Boat Speakers: 4 pairs of Wet Sounds XS650 coaxials. Added Blue LED micro dots on the back of the tweeters.
Subwoofers: 3 Wet Sounds XS-XXX woofers. 1 XS-XXX under drivers footwell in 1.4 slot loaded ported box. Back lit plexi trim panel. 2 XS-XXX under passenger in 1 cu ft sealed, reverse mounted. (you can see 2 vents that were cut in, these are the vents from the front of an RZ4. These were cut in for the original single woofer firing back. They are not used now and will be filled later)
Amps: All Hertz Italian made amps. 3 of the HP4 models and 2 of the HP1D. 1 HP4 on the PRO 485, 1 HP4 on the PRO 60 and 1 HP4 on the XS650. 1 HP1D on the XS-XXX drivers side, 1 HP1D on the 2 XS-XXX on passenger side.
Head Unit and EQ: Clarion CMD5 with transom remote in rear and drivers side. Wet Sounds WS 420 EQ flushed into bottom side of dash. Harmon Kardon Idrive I Pod controller. Screen flushed into dash. Control Knob flushed into dash where starter key was. Starter Key relocated to 12 volt plug location.
Amp Rack: I designed a Thermoelectric cooling amp rack. There is a thermoelectric cooler attached to a billet aluminum plate. 2 fans also attached to the plate. All amps are bolted to the cooling amp rack. Ice Cold cooling!!
Batteries: 6 Kinetik batteries with 2 Kinetik on board charger/power supplies. 4 HC 2400 models. 2 in each rear compartment. 2 HC2000 hidden under fuse panel. 2 more factory batteries on board. 150 amp Balmar alternator on order. High Amp Perko for switching. We have also built panels to cover the rear batteries now so we can throw some extra ballast on top.
Wire: All Tsunami 0 ga for amps. Tsunami 12 ga for speaker wire. Tsunami fuses in plexi panel with LED's. All Tsunami RCA's.
Motorization: The seat backs on both the front and rear on the passenger side and the seat back on the drivers front are all opened with 12 volt actuators controlled by a switch on the dash or a key fob. This was done for some added bling and some added security. You cannot open the seat backs without the power on. And the Perko is a locking one. So once the boat is locked up. You cannot get to the amps.
Boat was on display at the 2008 CES show. Mad Mike from Pimp My Ride loved it!
Will be at Texas events with it this year for everyone to see and hear.
Thanks,
Tim
Wet Sounds
System Breakdown.
Thanks,
Tim
Wet Sounds
