Originally posted by Razzman
View Post
Transom light
Check these bad boys out; http://www.plasmaled.com/high_power_module.htm look at the 008 3 watt magnifying version, red, blue or white, aluminum housing and it mounts from the rear. You could use a rubber gasket with sealer and it would be totally waterproof and super trick looking. Best of all the 3 watt version is only $20"Call me anything you want ... Just don't call me NOBODY!
Originally posted by dogbert View PostLooks like the smaller one could be a surface mount!"Call me anything you want ... Just don't call me NOBODY!
Originally posted by talltigeguy View PostI have noticed that waterproof LED's are dirt cheap. Most of the OEM are just mounted on the transom and then a wire and switch on the dash. I have been wondering if it would be so much cheaper to do it yourself. I find it hard to beleive that they are worth a $500 option.
It seems it would not be much labor to just drill a hole, seal it up, run wire and have your own underwater transom light.
Am I missing something here?
I would have to do a more detailed search to find exactly the right light, but this livewell light is like $10: http://www.boatfix.com/catalog/569.pdf
In response to your questions about the Recess Starr Light. Yes, it will work for underwater transom lights on your boat. It will require a 1.25" hole for mounting and as for the brightness, you can compare it to the brightness of a refrigerator light bulb. I hope this answers your questions.
Thank you!
Roni Lehmberg
Sales / Customer Service
Innovative Lighting, Inc
phone: 515-388-1011 ext. 115
fax: 515-388-5549
web: www.innovativelight.com
e-mail: ronil@innovativelight.com
If it's anywhere near as bright as the bulbs in my fridge it should work pretty good. No where near as bright as the Abyss lights but it should be ok. Add two or three and you're rockin'Attached Files"Call me anything you want ... Just don't call me NOBODY!
I've posted this before, but these are some pretty good looking lights that are surface mounted.
http://www.abysslite.com/
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by mtnsmith View PostI've posted this before, but these are some pretty good looking lights that are surface mounted.
http://www.abysslite.com/Be excellent to one another.
Probably, especially for a freshwater boat, I like to see things made for a saltwater environment since that is where I boat. A friend of mine is trying to make some out of polycarbonate with a stainless bezel to look good, if he ever gets these things made they will be awesome, they will be about as bright as the $1000 ones for about $100 each. Plus instead of round he is planning on making them about 6 inches long and 1.5 inches tall, that way the light will spread across the transom instead of being in a ring...should look good. Here are some a dude made out of acrylic on one of the fishing forums I visit...similar concept, just not as sleek.
http://www.thehulltruth.com/forums/t...179810&start=1
OK so here's another option:
Check out the DM-302 Brass: http://www.theledlight.com/LEDTriCluster.html make sure to click the dimensions link."Call me anything you want ... Just don't call me NOBODY!
And yet another option: http://www.theledlight.com/polaris.html This one actually is waterproof to 9.8 feet!"Call me anything you want ... Just don't call me NOBODY!
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by Razzman View PostOK so here's another option:
Check out the DM-302 Brass: http://www.theledlight.com/LEDTriCluster.html make sure to click the dimensions link.Be excellent to one another.
