Originally posted by Lucky 275
View Post
Tower speakers???
Originally posted by Big Wave View PostI Put the FAE on last summer. Every boat should have one. It is the best thing I have added.Honey I'm home!
I ordered mine today and plan on having a full writeup on www.wakeboatworld.com. If you plan on ordering one, I have links and info on the site.http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by time2kyl View PostCan't decide if I want to add it or not. I have never surfed and I'm not sure I want to start because then I'll want to spend even more moneyhttp://www.linkedin.com/in/zachgarcia
http://www.facebook.com/people/Zach-Garcia/1327360382
Originally posted by spharis View PostI ordered mine today and plan on having a full writeup on www.wakeboatworld.com. If you plan on ordering one, I have links and info on the site.
Ok just kidding ya.Let it be!!!
21TigeToGo
0Originally posted by Jason B View PostIt's too ugly. If it looked better I'd get it....call me shallow.
Ok if you insist
Hi there dude! I am new and I follow orders stillOnce Upon a time I saluted.
Your shallow, a 1 inch puddle. Slightly discolored
You told me too
Once Tige gets my boat made I might put one on
Ordered on 11th don't have production date yet.
Nice nite great thread poor .......humorLast edited by 21TigeToGo; 02-15-2008, 07:09 AM.
Can't see it when the boat is in the WATERMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Guest
Originally posted by chpthril View PostOk, you've got what Tige calls the "Premium Sound System".
With the above suggestion, I have one word.....RUN, run very fastYou cant parallel a pair of 150 watt RMS speakers into a pair of 75 watt RMS speakers for a lot of reasons: sound quality, balance, volume, heat generated by the amp.
You can get a good 2 chnl or smaller 4 chnl and run bridged, for less then $200. If your Lucky, the boat may be wired for that 2nd amp, and all you would need to do is wire the tower.
The MX350.4/ZX350.4 is an inexpensive 4chnl that is perfect for 1 pair of PRO 60's with 175 watts x 2 bridged @ 4ohms.
Below are the Kicker specs on the Tower Speakers , The two channel amp for the Tower Speakers and what I believe is the Amp for the Tige Premium Sound System.
New Kicker KS60 Tower Speakers 2ea
Features:
6 1⁄2” Coaxial Water Resistant Speakers
Our Loudest Speaker!
Kaladex Dome Tweeter
Polygraphic cone with a ribbed foam surround
Sensitivity * 90 db
Frequency Response: 43-20k
RMS Watts 6-90, peak watts 130
New Kicker ZX 250.2 2 Channel 500 watt Amplifierfor Tower Speakers
RMS Power
85 watts x 2 at 4 ohms (125 watts x 2 at 2 ohms)
250 watts x 1 in bridged mode (4-ohm stable in bridged mode)
Peak Power
171 watts x 2 at 4 ohms (250 watts x 2 at 2 ohms)
500 watts x 1 in bridged mode (4-ohm stable in bridged mode)
Variable high-pass/low-pass crossover (50-200 Hz, 12 dB/octave)
Variable bass boost (0-18 dB at 40 Hz)
Speaker- and preamp-level inputs
Preamp outputs
Tri-way capable (Tri-Way Crossover required)
Fuse rating: 40A x 1
8-gauge power and ground leads recommended wiring and hardware not included with amplifier
Existing Premium Sound System Amp
Kicker ZX 700.5 700 Watt 5 channel amp
Class D Multi-Channel Amplifier
RMS Power Rating:
4 ohms: 70 watts x 4 chan. + 210 watts x 1 Class D Sub channel
2 ohms: 85 watts x 4 chan. + 420 watts x 1 Class D Sub channel
4 ohms (bridged): 130 watts x 2 chan. + 420 watts x 1 chan. (2 ohms sub channel, 210 watts @ 4 ohms)
Peak Power Rating:
4 ohms: 140 watts x 4 chan. + 420 watts x 1 Class D Sub channel
2 ohms: 170 watts x 4 chan. + 840 watts x 1 Class D Sub channel
4 ohms (bridged): 260 watts x 2 chan. + 840 watts x 1 chan. (2 ohms sub channel, 420 watts @ 4 ohms)
Bass Boost Remote Control: 0 - 18dB at 40Hz
CEA-2006 Compliant
24dB per octave Crossover:
Active at 50Hz - 200Hz
High Pass, Low Pass, or Full-Pass selectable
4 gauge power/ground leads
chpthrl
Above is the configuration that I went with for a low cost addition to the existing Tige Premium Sound System to add an average (not great) pair of tower speakers to the system.
Do you see any serious issues with the Kicker ZX250.2 and the Kicker KS60 can speakers for the tower? Each speaker will be wired to it's own channel on the ZX250.2.
Since it is Ebay I can't return but the KS60's were under $300 with shipping and the amp was around $80 including shipping.
I think things are coming together on other fronts while I am waiting to get the Fruit Salad Boat on its low boy trailer. I have found a 12" drawbar to lower the trailer front to help get it in the garage and I pick it up tomorrow from Advantage Trailer. (The drawbar not the boat).
The only other thing I need to figure out is how to add a long life battery in the system. First I have to figure how much of the wiring shell they installed at the factory and go from there.
Hey thanks for all the help.
I am into digital electronics not this analog stuff. Actually studied digital state machines & designed add on hardware for DEC systems and micro based firmware systems years ago and landed up dwelling in the oh so fine world of software. I am not a consultant and have been out of coding loop for a while now with damn mgmt role. Same company w diff owners since I was a kid in 81
Originally posted by 1Lab_trainer View PostWell I spent some money on Ebay the other day for 2 Kicker Tower Speakers and a Kicker amp to drive them since the rest of my system is the Tige Premium Sound System.
Features:
Sensitivity * 90 db
RMS Power
Peak Power
Preamp outputs
RMS Power Rating:
Peak Power Rating:
CEA-2006 Compliant
chpthrl
Adding a 2nd battery be a great addition. It will allow you run the system with engine off for a couple of hrs, and not worry about a dead "starting" battery. It can be done for about $150 and most of that is the battery.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Here's a great source for getting your wire / cable online. Good quailty stuff at a great price: http://www.knukonceptz.com/"Call me anything you want ... Just don't call me NOBODY!
