Can't afford other toys?
Post up pics of your "other" toys!!
Originally posted by jake View PostCould you please provide instruction on the fisting part.
Thank you.
• Two slices of bread (if not pre-sliced, approximately square length and height, approximately one inch in width or thickness)
• One dull knife
• One jar of peanut butter
• One jar of jelly
• One clean surface (plate, cutting board, etc.)
Given that all the necessary items are present, you begin by laying down two slices of bread on the table directly in front of you. Pick up the jar of peanut butter in one hand. With the opposite, unscrew the top in a counterclock wise fashion. Once removed, set down the top on the table. Holding on to the open jar of peanut butter, pick up the spreading utensil with the free hand. Grab a nice portion of peanut butter on your knife. Put down the peanut butter. With the hand that is now available, pick up either slice of bread in a fashion that the top side of the bread is visible. Maintain and open palm w/ finger slightly bent to keep the slice in place. Carefully apply the knife with the scoop of peanut butter to the slice of bread. Gently spread the peanut butter so that it is evenly distributed. Lay down the piece of bread w/ peanut butter on the table next to the untouched bread, peanut butter side up. Now, set down the knife. Using one hand of the two that are available, pick up the jelly jar and open the jar in the same manner as the peanut butter jar. Set the top down and pick up the knife w/ your free hand. Insert the knife into the jelly jar and scoop out a decent portion of jelly. Because the jelly is quite unstable, you practice caution when holding it. Carefully set down the jelly jar and pick up the slice of bread with your free hand. Be sure that the slice does not have peanut butter. Hold the slice in the same manner as the previous slice. Gently apply the jelly to the slice of bread. spread the jelly so the that all the jelly is evenly distributed. Next, set down the knife. Holding on to the slice of bread with jelly in the same manner, pick up the slice of bread with peanut butter. Be sure to pick it up from the sides so that you do not stick your fingers in the spread. Adjust the slice of bread so that it is held on and open palm w/ slightly bent fingers. Make sure that the peanut butter is facing up. Bring both pieces of bread together as in a clapping motion, but with a fraction of the force. Maintain this your hands clasped while you rotate your hands 45 degrees. Remove the top hand, and there you have it.....and peanut butter and jelly sandwich.Watch this, hold my beer……………
Originally posted by 69BUG View PostI don’t know about the fisting thing?? But it is lunch time so go off and make lunch and this is how you do it
• One dull knife
• One jar of jelly
Wow! I can't wait to try this out.
• One dull knife
• One jar of jelly
BUG,
For some reason this made my afternoon!! That was hilarious!
Jake,
As much as it makes for good reading when we're bored, YOU HAVE PROBLEMS.
1977 Monte Carlo T-Top. My Grandparents bought this new back in 77 and it has been garaged ever since. I took if off their hands a couple years back. 69,000 org miles, Original EVERY THING, Super Clean almost showroom ready except for that damn dent just in front of the passenger door.Attached FilesI'm going old school- I'm bring back the SKURFER!!!!!!
