Cooler insulation
    I think Tige should have a new kegerator/ballast option.
    Freude am Fahren.
      Isn't that what the V-Drive compartments are for? Kegs make great ballast. The more you drink the less dangerous your wake gets for you
        I can't put a keg in there, that's where I make the FAT GIRLS hide when my friends come around.
        Fat girls are like mopeds; fun to ride until your friends see you!
        BTW: my wife doesn't know I keep fat girls back there so let's keep this our secret ok?
          Too much information!
            I see this thread is super old, but dont see any more on this topic. Anyone try this with "great stuff? I am sick of ice lasting me 2 hours hours on a 75 degree day! I have an 09 rz4 for reference.
            Sent from my SM-G935V using Tapatalk
              Is your cooler under spotter seat butt cushion??
                It is built in on starboard side behind the lockable storage and garbage can.
                  I have used it in the past and it will give you improvement over what you have now. The biggest problem you will have after using the foam is the lack of a seal on top of the compartment. Get some thin weatherstripping from Home Depot or other similar store of your choice and install it around the cooler so you get an air tight seal when the seat is in place.
                  FYI - be careful with 2 part urethane foam, it can damage things if it does not have room to expand. Your cooler is the weak point in that area of the boat and it will crack if you use too much foam.
