My plan is to install a 1400 lbs of ballast.
2008 Upgrades, what are your plans?
anhaney
- Get my son to finish his Eagle Project.
- Install amp and add two tower speakers.
- Build a speaker box for under the Dash of the boat. Maybe add another 10" sub in another location of the boat still working on that.
- Polish the trailer wheels out so they look like chrome.
- Gel Coat Repairs.
- Swim Deck gel-coat and replace the rubber mat's.
- Get the vinyl replace and get the rope burns out of it.
- Help G-Money with his Ballast system.
- Help Eksilva with his ballast system.
- Work to pay the bills.
- And somehow figure out how to accomplish all the tasks.Last edited by anhaney; 01-03-2008, 03:21 AM.
anhaney - get that Eagle project done! I think i got mine done when I was 17 1/2 years old, barely got the Eagle Scout before I was 18.
Scrub and wax - done
LED light install. Factory LEDs are standard in storage compartments. I am adding ones under the dash to light up subwoofer, and then along floor area.
Troubleshoot shower install that I just finished. Leaks near regulator valve controls. Also replace "ACC" rocker switch I wired shower to with "Shower" switch. I got this switch for $1.50 at Paradise.
Heater install??? Maybe.
I'm planning on a navy and black 24vé w/ an optimizer 6500 and Line-X'd Magnum trailer. Possibly with the Z tower, but not sure. Planning on factory wetsounds in the boat, but will most likely go with the "trio" on the tower. I'll be having the ski dock do a custom sacked ballast w/ the factory holes cut and hoses installed. Thinking 500-lbs in each corner should do it.
I'm also wanting to get the rear speakers installed in the seatbacks w/ the upholstery cut and formed around them. This wouldnt be hard- it would only involve making the speaker cutouts higher, then cutting the vinyl, backboard and foam so that there's a 1-2mm gap from the outside diameter of the speaker grille, then stapling the vinyl to the backboard, going through the hole. The middle speakers should be mounted to the top of the dash, on either side, just behind the windshield.This would result in MUCH better sound quality... since I dont have ears on my ankles or knees.Freude am Fahren.
