I have a question regarding priming an inboard engine. Does the cooling system need to be primed, after it has been drained for the winter? I was talking to a mechanic the other day who thought that inboards require the system to be primed in order to draw water from the lake for the cooling system. This didn't sound right to me, but I figured I'd ask.
Priming?
The only diff between an inboard and an I/O is the location of the pickup. With an ample water supply, lake or water hose/fake-a-lake, it will prime up within a couple seconds of firing up.
Replace in the spring is a good idea any way, but mine goes through this 5-6 times a winter. I drain on the ramp and launch dry the next time, will get new one in spring and stay "wet" the rest of the season.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
tessa
Originally posted by chpthril View PostThe only diff between an inboard and an I/O is the location of the pickup. With an ample water supply, lake or water hose/fake-a-lake, it will prime up within a couple seconds of firing up.
Originally posted by tessa View PostHow often should the impeller be replaced? Once a season or once every 2-3 seasons? On my I/O which was 13 years old when I got rid of it I only replaced it twice.Common Sense is not so Common
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
I replace it yearly because I do not have enough recreational time to spend part of it dealing with a mechanical failure. It depends on if you have more money than time. Unfortunately, in this case, I have more money, since it does not cost that much.Be excellent to one another.
tessa
Originally posted by talltigeguy View PostAnd I bet you replaced it after you got stranded on the lake?
From what I have seen it seems relatively easy to change on the Vortec,therefore I will change it everytime I winterize.
What does an impeller run for an 07 20V?
Money for a replacement impeller for the I/O was not an issue. It was tearing down the lower unit to change the impellar was a royal pain and time consuming.Last edited by tessa; 01-04-2008, 12:00 AM.
Originally posted by laserfish View PostI replace every year from experience. Too many trips cut short with a boat full of people. Cheap insurance.Dale
2000 21i Tige
tessa
I'd bet that small pieces of debris could damage the impeller. There is not a lot of clearance between the veins, and zero between the veins and housing. If you waters are really bad, It would be worth installing a strainer. If it clogs up....clean out and keep going. Impeller goes, better hope you have a spare or the day/weekend is over.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
anhaney
Originally posted by tessa View PostI replaced it when the boat was 6 years old and again at 11 years old and it burnt up and smoked the cooling system 2 years later(oops that makes 3) and we had to call it a season to rebuild the top end, bellows,valves,tilt pump and a host of other stuff. Used the boat 2 more years after thata nd then got rid of it.
