Guys, does anyone know the part number for the Marine Power impeller. It should be 09812B superceded to 09812B-1.
Impellers
anhaneyTags: None
anhaney
Lee says the 09812B is the correct. So I would say the the 09812B-1 is the correct suppersession. You should be good to go.
lee
Mr.Tigé Dealer Know It All Guy Join Date: Jan 2004
Boat: Tigé
It does not use a Merc impeller but a MAYFAIR/JOHNSON Impeller part number 09812B.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
We trailer 20 mins to the lake, so if it goes out.....no big loss, just a day on the lake not a whole vacation.
It's really a maintenance item. Change it every spring and you should never have a problem unless something weird goes on.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
anhaney
Originally posted by chpthril View PostWe trailer 20 mins to the lake, so if it goes out.....no big loss, just a day on the lake not a whole vacation.
Also you should keep a spare belt on board. Ask DOMSZ06 about that. He will agree.
Originally posted by anhaney View PostIf you plan to frequent bigger lakes like powell and Mead I would have one on board as an extra. What I do is change it every spring then I keep the old one if its okay for an emergency back up. It just sits in my tool box. Each year I throw the previous years spare away.
I appreciate the comments, I have bought a new boat every year the past 3 years and never had to worry about maintenance. Now that I have the RZ2 I will keep it for a long time and it is good to know this maintenance tips.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by eksilva View PostLike I said, I am not a very handy guy. Is there anywhere I could find instruction on how to change the impeller and the belt?
Your is shaft driven right off the front of the cranks shaft.
Give me a minute and I'll find a link with a pic.
Found one http://www.tigeowners.com/forum/show...75&postcount=5
*EDIT* Remove 4-5 bolts with either a flat blade screwdriver or (i think) a 5/16 wrench/socket, remove cover, note direction of fins on old impeller and pull out. clean out and pieces, apply a little silicone past to the housing, install new impeller by rotating so the fins fold in the same direction as the old one was prior to removal, replace cover, install and tighten bollts.Last edited by chpthril; 12-21-2007, 05:01 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostOther then being hard to reach on a V-drive like your RZ, the Marine Power setup is really easy to change.
*EDIT* Remove 4-5 bolts with either a flat blade screwdriver or (i think) a 5/16 wrench/socket, remove cover, note direction of fins on old impeller and pull out. clean out and pieces, apply a little silicone past to the housing, install new impeller by rotating so the fins fold in the same direction as the old one was prior to removal, replace cover, install and tighten bollts.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
Originally posted by eksilva View PostCool I printed that out and I am going to leave it the boat. Do you have an spare propeller as well? They are not cheap, I am always very careful at lake Powell, but you never know.
The key is to change it before it gets real old. A bad impeller will heat up and score the housing and from there, it will shorten the life of every other impeller til you replace the housing.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostMy dealer replaced my whole housing this spring under warranty due to leak. So this spring, when I do it, I will put the old one back as a spare
The key is to change it before it gets real old. A bad impeller will heat up and score the housing and from there, it will shorten the life of every other impeller til you replace the housing.The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
