Tower Lights and Speakers
    being built
      homade
      those look good, is it aluminum pipe?
        Stainless steel, it was free from my dad's company.
        If I did it again, I would probaby use aluminum and put four up there.
        But for two, it rocks hard, especially with the four polks in the boat and Fosgates pushing it all
          Nice job Cheeky
            hey.. where can I find some tubing like that? I want to go with stainless, since it is heavier and will reverberate less.
            Freude am Fahren.
              I'm not sure where to find it. My dad is a Mechanical Contractor, so I took some scrap and had one of his welders piece it together.
              I still put sound deadening material in it, even as heavy as it is.
                hmmm can you ask him the specs on the pipe?
                Freude am Fahren.
                  It is 6 1/2" OD , I think Sched 20. I will get the specifics from him next time I see him. Just took some thin SS plate and welded one end shut, the other welded a plate with open center for the speaker to attach to
                    Here is my set up. A set of B 50's and B62's along with a Boss lightbar. I have since upgraded to a Lightening Accessories bar and love it. The Mako set is gorgeous and the 6x9 box from Loudliquid should crank. I would recommend checking out www.lighteningaccessories.com and www.monstertower.com for some good speaker set ups.
                      sammamish... is that the Millennium dash?
                      Freude am Fahren.
                        Yes, it sure is.
                          niiice very niiice.
                          Freude am Fahren.
                            Whoops. www.lightningaccessories.com. I can't spell today. Where is the spell checker with this message board!
                              I've used the Titan, with the 6 DST (Daylight Saving Time) lights, 2 facing forward and 4 rear, they worked really well. The Titans actually have a shield inside to direct the light better along with a special lens that is supposed to help. I have been impressed with their output.
                                Can you guys really see ahead with tower lights? I havent used any but I have used spot lights and couldnt see a thing without puting it below the rub rail.
