That's about $60 cheaper than an Enzo sac so that is quite a savings over what would normally have to spend. I will want one, I just don't have the $$$ right now.
Third Party Ballast System
there is still time,
what we should do is set a order date and them submit it in time to have for spring...
This will give time for people to see this and then save the pennies
Maybe a new thread titled "Fat Sac" group buy for All VE and RZ series boats.
I would also suggest March15th as a cut off. so we all have them by April.Tige owner since 2006
What dimensions are you looking at going with? Here is the best combo of your measurments and mine:
Main part: 31L x 22H x 21W
Leg: 55L x 12H x 21W
Comes up to around 1k lbs depending on which boat, which side.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Timmy! View PostAny idea on the # of Enzo's sold vs other makes? Just curious why Fly High made a custom sac for just that boat. Maybe it was Inland Surfer who pushed them that way?and it took up most of the rear storage.
Originally posted by Timmy! View PostEnzo boats, I assumed they made the Enzo sac for the Enzo boats...Got me there, but I was in an 08 Enzo at the boat show, no sacs, but hard tanks
you guys are remembering to put weight in the front, right? Especially with the convex-v hull, focusing all your weight in the back will cause the wake to be severely washed out. You can provide lift with TAPS, but then you're just working against the ballast you've installed. The weight needs to be balanced throughout the boat.Freude am Fahren.
Originally posted by Ruune View Postyou guys are remembering to put weight in the front, right? Especially with the convex-v hull, focusing all your weight in the back will cause the wake to be severely washed out. You can provide lift with TAPS, but then you're just working against the ballast you've installed. The weight needs to be balanced throughout the boat.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
