Perfect pass for 99" Tige.
    Do they have them? I can only find them for boats 06 and newer.
    Help
    For Those About To Ride We Solute You
    Its not really year specific, it should work on any boat thats not "drive by wire"
    Which means instead of a cable, (which yours most likely has) a drive by wire engine is controlled by the ECM.
    Common Sense is not so Common
      Call PP, and they can hook you up with the proper one. I have a 2000 21V and ordered mine direct several years ago. Installation is a breeze once you get over putting a big ol hole in the bottom of your boat.
        I put a Wakeboard Pro in our boat last year. Perfect Pass lists the Wakeboard Pro for $1099 on their website. I don't know if shipping is extra. Got ours at: http://www.schnitzskis.com/perfectpass.html for $1050 with free shipping. When I called in the order I asked and was told they don't stock them, they drop ship the order and it comes direct from PP. There are many different gauge styles which would make it hard to stock them. I got the 3.5" display and mounted it in a blank panel where the radio was. That put it down low on the dash so it would be easier to get to while driving. Also, put 2 other gauges in the panel - Depth gauge & Fume detector.
          I've got the Wakeboard Pro on my boat. Works like a champ. Can't imagine not having it. If you do install it, though, I'd replace the speedo and not the tach. The speedo on PP is way more accurate than the one that came with my boat and I do rely on my tach quite a bit more. You can get the display with the Tige logo on it, so you'll know it's for your boat.
          Of course, my boat's a bit longer than 99"
            my RPM gauge doesnt work....
              You might want to get it fixed.
                The perfect pass has an RPM reading on it, but it is not as easy to read as the original Tige RPM. I took Dog's advice and replaced my Speedo instead of the RPM.
