no I didn't, didn't think of it, I will check.
Stock Tower Swap for Samson
Ragboy,
Ask Scott if the Razor & the Switchblade are the same as far as weight & function of raising & lowering. If so, it's a piece of cake. I have to lower my Razor to get it in my shop each time. After it's in, I raise it back up. I do it most of the time by myself. REALLY EASY!! Like K said, or maybe it was Sparky, it only takes a minute or 2 at most.
Originally posted by Lucky 275 View PostI'm confused... is that your boat in the garage? Isn't that the e tower?
Originally posted by b/w05 View PostRagboy,
Ask Scott if the Razor & the Switchblade are the same as far as weight & function of raising & lowering. If so, it's a piece of cake. I have to lower my Razor to get it in my shop each time. After it's in, I raise it back up. I do it most of the time by myself. REALLY EASY!! Like K said, or maybe it was Sparky, it only takes a minute or 2 at most.http://wake9.com/
Rag you have it switched around. You have the e series tower, and the one without the horizantal tube is the z tower which is even harder to take up and downEverything happens for a reason
Originally posted by ragboy View Post
y, they are pretty much the same, switchblade doesn't have that horizontal tube, and is 2 7/8" thick.Everything happens for a reason
Originally posted by CP3 View PostRag you have it switched around. You have the e series tower, and the one without the horizantal tube is the z tower which is even harder to take up and downhttp://wake9.com/
