So why does the Marine Power Engine Owners Manual say that fogging isn't required on a fuel injected motor?
Winterize
Originally posted by Tige'20i View PostSo why does the Marine Power Engine Owners Manual say that fogging isn't required on a fuel injected motor?
That's a very good questionsince fogging has nothing to do with the fuel delivery type, It's about preventing rust on the valves, pistons, cylinders, etc, caused by moisture.
anhaney
Here is the issue on Fuel injection
If you fog multi port engines the injectors will gum up from the fogging oil over the winter. thus causing you to have to do injector work at the start of next season.
Originally posted by anhaney View PostIf your engine is a throttle body or carburetor engine Fog it. If your engine is a Multi Port Injection engine do not fog it.
Anhaney,
I don't disagree with your info very often, but this I would have to. If fogging oil caused any gumming issues, we would see this in valves not seating and causing loss of compression, seized piston rings causing oil blow-by and consumption and loss of compression and mis-firing/fouled plug(s) due to build up on the electrodes.
Also, gumming of the injector pintle valves cone, on the discharge side, is very rare due to the spray of fuel keeping it clear/clean. If a thin layer of fogging oil where to dry on the injector cone, it would be washed off on the first start up by the fuel and it's additives.
Last, the injectors a placed at an angle. Not quit parallel with the intake runner, but by no means perpendicular to the runner and slightly recessed. Vacuum created by the engine will pull the air/fogging oil past the injector tip. Very little swirling going on in the intake, so any fogging oil left in the intake upon shut down would settle in the floor of the intake runner.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
anhaney
Synthetic oil is not a good oil to keep in the engine for the winter. The stuff is so slick that it tends to drain of the parts while sitting for long periods of time and that is the bigger issue than fogging in my opinion. Here in CA I just start my boat up through the winter so I don't really worry about winterizing it. Although this year I may.Last edited by anhaney; 10-04-2007, 02:10 PM.
Originally posted by anhaney View PostIf you fog multi port engines the injectors will gum up from the fogging oil over the winter. thus causing you to have to do injector work at the start of next season.
anhaney
Originally posted by Tige'20i View PostWhat about spring fogging oil in the cyclinder of a muli port thru sprark plug holes?
