Had a chance to check out an 08 22Ve last night that my dealer unloaded Fri. and just wanted to share some of the first things I noticed.
Pro's:
No more "friction fit" seats in the main cabin area......much easier to get into storage and cooler.
Ballast switches are on the drivers console below the Speed-Set.......Moved from the side panel, below the throttle, where they were easy to click on with you knee when you swivel the seat.
Board racks now lock on the outside which makes starting the threaded hold-down handle much easier.
New 320hp seems almost as strong as the 340hp
Con's:
The flip over corner cushion/step is a little smaller now, 'bout the size of the RZ2.
Overall I was impressed with this boat. Keep up the good work Tige
Pro's:
Con's:
