hull molding
    hull molding
    The 2 guide pole on the back of the trailer that I assume are to help when you are loading you boat on the trailer. I am having a problem w/ my molding between the top and bottom hull coming off from time to time on one side of my boat. I know why it happens but w/out replacing the entire molding around the boat I don't have a permenent solution. I have a damaged spot and have been working on it but can't get it fixed. My guide poles are PVC and they do spin, but the molding still comes off sometimes. I do have some really good strong silicone that I was going to put a bead inside the track to hold it in place and buy some of the black Tige padded things to go over the guide poles. Is this my best solution?
    TIA
    Dale
    2000 21i Tige
    I found my covers on Ebay for 15$ - much cheaper than the dealer.
