ATTENTION WETSOUNDS!!!
    Originally posted by da.bell View Post
    There is the Lake Mead Reunion in October!!!!!!!!!!! What better place to be....
      yeah that would be some fun
      Originally posted by G-MONEY
        What is Gloss White 6.0 400 HP?
        You painted the engine?
        Be excellent to one another.
          That is what I understood..... Custom engine also????
            Very nice. I love the way it looks from afar.
            Did Marine Power customize your engine color? Id like to see how that looks. Cant wait to see more pictures.
              very interesting. A white engine? man would be cool, but what a PITA to keep clean from all the pieces of rubber from the belts. Needless to say it's still a sharp looking boat!
                You said custom tower, it looks like the Z series tower...What did you do that is different?
                  I think the powder coating on the uprights is customizing it.
                    It also looks like the cross member is straight instead of curved on the inside of the tower. Unless that was already mentioned.
                      it was mentioned
                        Originally posted by wetsounds1 View Post
                        Thanks for all the great comments. I am very happy with the way everything turned out!
                        I will get more pics next week.
                        But here are some details.
                        2008 RZ4
                        Boat Mate Triple trailer with 18's
                        Custom Gel coat layup
                        Gloss White 6.0 400 horse
                        Custom interior with ostrich trim
                        Dual Led transom lights
                        6 batteries with dual isolators (4 of them Kinetik 2400)
                        Full Vinyl wrap done by RE Boat
                        Custom Tower with straight bar and powder coated legs
                        Vision Air seat
                        Factory ballast system and added custom surf ballast
                        Fiberglass swim platform (forgot to put it on in the pics, almost drove off without it!!)
                        Stereo
                        1 pair of Wet Sounds PRO 485
                        1 pair of Wet Sounds PRO 60
                        4 pairs of Wet Sounds XS650
                        2 Wet Sounds XS-XXX 12 inch spl subs (top secret!!!!!)
                        1 Wet Sounds WS-420 EQ (coming soon!!!)
                        Amps are all cadence for NOW. (something really really cool will be replacing them soon!!) 8000D on each sub, 3002 on 485, 1502 on 60, and 1004 on xs650. All in all about 5000 watts plus.
                        Ran all Tsunami wire and rcas and fuses etc... 0 GA for everything. Went 0 ga direct into every amp with 0 to 4 ga adapters.
                        Moki, Led's come later
                        Tige Duner. Led transom are new factory option for 1. I just added another one.
                        Domsz06. Nope not free. Boy I wish though!!
                        More to come later. Got to go. To the Lake!!
                        Tim
                        Wet Sounds
                        woah... 4 kinetik 2400s @ 2600amps each!
                        That translates to 10400 amps or 124,800 watts @12 volts, or 149,760 @14.4 volts!!!
                        What kind of alternator are you pushing that with?
                        sick setup man!
                        Freude am Fahren.
                          Sounds like a small nuclear reactor was needed.
                            even still, if he charges each battery overnight, he should be able to run 5k watts for a decent amount of time with over 10,400 amps (plus the other two batteries).
                            thats a lotta juice!
                            Freude am Fahren.
                              Actually, he downsized from this model, but kept the same powerplant:
                                it can be done, i do it and have around 6k watts
