Tight Steering?
    Tight Steering?
    I have an 04 21i. The steering keeps getting tighter and tighter every trip. Is there a zerk fitting on the steering system that needs to be lubed? I have checked the rudder for any sign of damage, there is none. It must be in the gears on the head unit or in the cables. any suggestion?
    http://www.bestonline-biz.com/pips
    Most likely you need a new steering cable.
      Thank you, I just found the thread that talks all about the same problem. I am going to try the full extension lube, then the cable replacement
        I think spharis has a tutorial for the cable replacement.
          http://www.wakeboatworld.com/index.p...d=29&Itemid=35
          Common Sense is not so Common
